SOS- PLEASE HELP!
Solved by i_build_nanosuits,
if it was running fine before and now you no longer hear any pump noise at all and the CPU is overheating then i think you have your answerYeah plus the fact that it came out of the blue probably signifies that something broke quickly, if it was thermal paste, then it should have been a gradual effect
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
