I am building a new PC and wondering if I need a wireless network adapter to be able to get WiFi?
If yes, whats the best budget one that has the best money to performance ratio?
If no, if I were to get one would it make my upload and download speeds faster than without?
Here's my build so far.
http://pcpartpicker.com/p/HNxbYJ
Thanks
https://linustechtips.com/topic/413739-wireless-network-card/
Thanks
What are you going to be using this build for? If youre going to be gaming, get rid of that expensive CPU and get a better GPU. Also overkill on the ram (if its a gaming rig). Now to your question, the answer is Yes.
https://linustechtips.com/topic/413739-wireless-network-card/#findComment-5566533
Sorry, should have included intent on initial post. I will be using it as a workstation/video editing so cpu and ram are very important.
https://linustechtips.com/topic/413739-wireless-network-card/#findComment-5566553
