Hi guys :(
I have recently bought these headphones on ebay and, well, maybe I shouldn't have.I can't get any sound if I plug them in to the Spitfire and if I plug them directly to the PC I get sound but the mic doesn't work.
The seller said that they were used but working perfectly.
Are they broken or am I dumb?
Core2 Quad Q9400 @ 3.00GHz ✦  8GB Corsair RAM ✦Asus P5G41Tm - Lx3 ✦ Sapphire R9 270 Dual-X ✦ WD Caviar Green 640 GB ✦ Seagate Barracuda 160GB ✦ Fractal Design Define R5 ✦ 1Life ps:jet 700W ✦
Lenovo Y520 - GTX1050Ti - i77700k - 250GB Samsung M.2 NVME SSD  :D
https://linustechtips.com/topic/413694-rog-orion-problems/
Did you try them on something else?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566066
ermm, nop xD I will
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566076
So I'vr tried them on my laptop and they work fine...
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566229
Try reinstalling drivers.
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566269
It's driver-less...
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566319
It's driver-less...
Ohh wow, does your computer work with other headsets.
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566332
YEs, But I think i've figured it out xD just messed with the audio settings and its working xD
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566353
Yay
https://linustechtips.com/topic/413694-rog-orion-problems/#findComment-5566464
