specs?
are the fans on your GPU spinning up?
have you tried hooking the monitor up directly to the motherboard?
https://linustechtips.com/topic/413617-help-me-please/#findComment-5565092
So im building a pc right now and everything is hooked up but when I turn it on the lights and fans go on but nothing comes up on my monitor, im thinking I havent hooked the cpu cooler up properly (x61 if that helps) any ideas thanks.
What is your build? Check all cables first.
https://linustechtips.com/topic/413617-help-me-please/#findComment-5565095
do you have any trouble codes shown on the motherboard
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/413617-help-me-please/#findComment-5565191
You need to connect the CPU_FAN header, my board refuses to POST without it.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/413617-help-me-please/#findComment-5565209
