More raspberry pi issues
So I got a new sd card I put noobs on it as a test. I accidentally started the installation. I didn't want it so I unplugged it. I know a bad idea. Then I formatted it. then I put openelec on it. When I plugged it in nothing happened. So I put noobs on it. On boot it said I didn't have enough space for installation. So I formatted it (over wright) and put noobs back on. When I plugged it in nothing happened. I need help ASAP. Have a good day!:)
https://linustechtips.com/topic/413295-more-raspberry-pi-issues/
It must be formatted as FAT 32 only
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/413295-more-raspberry-pi-issues/#findComment-5561073
ok I will check if it is fat 32.
When you're burning the IMG file to the SD card, use software like WinDiskImager
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/413295-more-raspberry-pi-issues/#findComment-5561147
i am on a Mac.
I found this on AlternativeTo: http://alternativeto.net/software/applepi-baker/
I have not used this software myself, proceed with caution
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
https://linustechtips.com/topic/413295-more-raspberry-pi-issues/#findComment-5561243
i think it is fat 32. I am not curtain.
Reformat it in disk utility
Then  download NOOBs and unzip and drag the files on the sd card, voila its ready to go.
https://linustechtips.com/topic/413295-more-raspberry-pi-issues/#findComment-5561427
