Nice build,
I would personally try and upgrade to a R9 380 if you can,
otherwise nice build
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5554686
Looks pretty damn good!
But, a 4690K is a bit overkill for such low end games, maybe get a 4460 and you could get a 290 or save some cash?
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5554691
there are some high end games i might buy
then go for a 4460 and get a 280X or 290.
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5554735
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5554780
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard  ($57.98 @ Newegg)  <<Buy from Newegg to ensure CPU compatibility
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($44.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($242.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($68.99 @ SuperBiiz)
Total: $738.87
Generated by PCPartPicker 2015-07-22 04:50 EDT-0400
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5554827
http://pcpartpicker.com/p/4QckZL Looking to play CS:GO,Minecraft and wondering if it would run 60fps 1080p
nice build  it works the way it is.
I would say, get a mirco atx that is z97 so you have 20 more dollars saved.
then you can try and get a better gpu ...
But your build is great ritherway so good jobz!
I am a ... NVIDIA FANBOY!
https://linustechtips.com/topic/412786-first-build-need-advice/#findComment-5557216
