I am currently in the process of choosing parts for a new PC I am building. I am stuck on which GPU to go with. I am on a pretty strict budget which I know makes it hard. I plan on upgrading in the future though. So, I will be running primarily Adobe Premier Pro CC and some After Effects CC with some other multitasking. I am having trouble deciding which card. I will be running dual monitors as well. My price cap is $150 ish USD.
i7 5820k
g.skill ripjaws 4 32gb ram ddr4
This is also what I have picked out so far for CPU and Memory.
Thanks so much in advance.
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/
why overkill on the CPU?
your build is kinda un-balanced
opt for the i7 4790K and you can set more money for the GPU
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553493
Because he is using it for video editing and content creation?
Maybe if it was for gaming you could say its overkill but for what he is using it for its fine...
But I do agree he is spending a lot on the CPU and then nothing on the GPU
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553529
4690k and a 980.
AMD Phenom II B55 Quad / unlocked dual core 4.3ghz CB R15 = CB 422
XFX R9 390 8GB MY RIG: http://uk.pcpartpicker.com/p/MVwQsY
Fastest 7770 on LTT . 3rd Fastest Phenom II Quad on LTT
PCSX2 on AMD CPU? http://linustechtips.com/main/topic/412377-pcsx2-emulator-4096x2160-amd-phenom-ii/#entry5550588
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553537
Adobe suite does use the GPU for OpenCL rendering so it makes sense to use the GPU for post processing
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553542
Ah didnt realise that, the CAD programs which I use are all CPU renderers so assumed those would be the same :P
My Rigs:
Case:
Case:
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553566
4690k and a 980.
He's using it for editing not gaming, that i5 will definitely struggle
CPU i7 4790K @4.8GHz | Motherboard ASUS HERO VII Z97 | Cooler Corsair H110i GT | GPU Gigabyte G1Gaming GTX 970 SLI | PSU Corsair HX750i
RAM Corsair Vengeance Pro 16GB 1866MHz | HDD Western Digital Red 1TB | SSD HyperX Savage | Case NZXT Noctis 450 OS Windows 8.1
Keyboard Corsair K95 RGB Mouse Corsair Sabre Laser RGB | Headset Corsair H2100 Wireless 7.1
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553574
Editing what? video?
LOL at needing any i7 for that task!
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553583
The 4690k is good, but he said he wants to MAINLY use it for productivity not games, a 5820k and 960 would do him fine
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553588
https://linustechtips.com/topic/412699-building-new-pc-gpu-help/#findComment-5553608
