Help choosing a GPU
Go to solution Solved by Swndlr,
390 :P
So I need help choosing a graphics card for my build. I have a 4790k and plan on playing on a 1440p 144hz monitor eventually, but for now I'm on a 1080p one. Which card would be the best for running games at 60 FPS on high-ultra settings, like GTA 5 for example. My budget is less than 500 USD.
https://linustechtips.com/topic/412675-help-choosing-a-gpu/
For 1080p 60, you'll need no more than a GTX 960, but since youre going to 144Hz 1440p, I'd say go for a 390(X).
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/412675-help-choosing-a-gpu/#findComment-5553321
