i need to build a machine that is going to be mainly used for image and 3d rendering.
i have a budget of 1000 euros ( i'm dutch ) and i'd like some advice on the specs.
A core i5 4690k is a great video rendering CPU for a budget rig. It has a solid clock speed, and will not bottleneck anything else.
16 GB of ram is usually enough for rigs in this range.
If you use adobe cs, a gtx 970 or 960 will be good for cuda acceleration.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/412496-rendering-machine/#findComment-5551352
Well you want a lot of CPU cores. AMD has many cores, but they are weak cores compared to Intel.
I'm sure you don't want a loud work environment, so the stock cooler just wont do, as it is loud.
You need a lot of Memory, 16GB should do it.
You are going to want to put those programs on an SSD so they load fast and preform very smoothly. You will also need bulk storage for everything that gets saved.
Having a GPU can help, but might not be necessary depending on the programs you use. I added one just in case.
Simple effective case.
Reliable power supply.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (€259.88 @ Home of Hardware DE)
CPU Cooler: Noctua NH-U9B SE2 37.9 CFM CPU Cooler  (€52.38 @ Amazon Deutschland)
Motherboard: ASRock B85M Pro4 Micro ATX LGA1150 Motherboard  (€70.09 @ Home of Hardware DE)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1600 Memory  (€101.00 @ Amazon Deutschland)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  (€139.00 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€56.61 @ Home of Hardware DE)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  (€204.50 @ Amazon Deutschland)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  (€40.07 @ Home of Hardware DE)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€95.91 @ Amazon Deutschland)
Total: €1019.44
Generated by PCPartPicker 2015-07-22 05:11 CEST+0200
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/412496-rendering-machine/#findComment-5553077
CPU: AMD FX-8320 3.5GHz 8-Core Processor  (€139.90 @ Caseking)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  (€129.00 @ Amazon Deutschland)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1600 Memory  (€106.16 @ Amazon Deutschland)
Storage: Toshiba  2TB 3.5" 7200RPM Internal Hard Drive  (€79.90 @ Caseking)
Video Card: MSI Radeon R9 380 4GB Video Card  (€269.14 @ Amazon Deutschland)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  (€38.20 @ Amazon Deutschland)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (€44.21 @ Amazon Deutschland)
Total: €1054.50
Generated by PCPartPicker 2015-07-22 10:25 CEST+0200
even tho its amd u still have a better core to core ratio then intel cores but intel would be a better choose if u had a bigger price rang around 2k
https://linustechtips.com/topic/412496-rendering-machine/#findComment-5554701
