i think it may be 75c but dont qoute me on that.
why are you stress testing an athlon anyway xD surely youre not using it for rendering etc.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/412057-safe-max-temp/#findComment-5545778
Well, keep it under 100°C... ^^
Then the lower you get the better, I'd say below 85°C is totally fine...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/412057-safe-max-temp/#findComment-5545801
Personally, I'd keep it under 75*C but you should really only consider it an issue if it goes over 80*C. A cooler might help or just setting the fan at a higher speed.
https://linustechtips.com/topic/412057-safe-max-temp/#findComment-5545858
So its alright that my fans speed up after a bit of time gaming?
It's normal. If fans don't go faster temps would be higher. AMD's fans can go up to 3200 RPM.
https://linustechtips.com/topic/412057-safe-max-temp/#findComment-5545922
Thank you I can stop checking the temps now when it sounds load :D
Well, you could always get a cheap cooler like the 212 EVO from Cooler Master or the Arcitc Freezer to keep temps down. I used to get 62*C pretty regularly and now I barely go above 45*C with the Freezer 13.
https://linustechtips.com/topic/412057-safe-max-temp/#findComment-5545964
