Intel Core i5-4690K 3.5GHz Quad-Core Processor
NZXT Kraken X61 106.1 CFM Liquid CPU Cooler
MSI Z97 PC MATE ATX LGA1150 Motherboard
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
OCZ ARC 100 120GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
MSI GeForce GTX 970 4GB Twin Frozr V Video Card
NZXT S340 (Black) ATX Mid Tower Case
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Build is designed for maxing at 1080P and slight video editing on a single display for YouTube videos, i am pretty much at my max budget but i can have some slight movement if it's needed, and i already have all the peripherals i need.
https://linustechtips.com/topic/411909-first-pc-build-looking-for-advice/
It's pretty good.
However get a different SSD and PSU
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
Get a different PSU. Like a EVGA GS or G2 series. The SSD is fine. The cooler may be overkill but it will,allow for some insane overclocks.
I'd get an r9 390 since it's just better then the GTX 970. Looks good though.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
A Samsung 850 evo SSD and an evga PSU
I'd recommend getting at least a 700W PSU to leave room for future upgrades if you're gonna be upgrading, which I imagine you will be. I have an 850W EVGA Supernova Bronze+ and it's completely silent and works great. I have SLI GTX 780's and 850W is plenty for my configuration. I'd also maybe try looking at another SSD. I got an Adata 256GB SSD off of amazon for $100. I'll try and find the link to see if it's still available.
CPU: Core i7 4790k - CPU Cooler: Thermaltake Water 3.0 Ultimate - GPU: Asus GTX 980Ti - Motherboard: MSI Z87-GD65 Gaming - Ram: 20GB Corsair Vengeance DDR3 @ 1600MHz - Storage: ADATA 256GB SSD, Samsung 840 Evo 1TB SSD & WD 1TB HDD 7200RPM - PSU: NZXT Hale90 V2 1000W Gold+ - Case: Phantek Enthoo Primo Black Exterior/White Interior - Display: Samsung 29" Curved Ultra Wide - Keyboard & Mouse: Razer Blackwidow Ultimate & Roccat Tyon - Sound: Razer Kraken USB Headphones, Blue Yeti, Logitech z313 Speakers
 May i ask why you all suggest an EVGA psu?
Corsair PSUs aren't all that great. Especially the CX series, one of the worst. The EVGA PSU, specifically the EVGA g2 series is made by SuperFlower. So basically a rebrand, but that's not bad, corsair does this to, almost all PSU makers do it. Well,SuperFlower is basically one of the best if not they are the best PSU makers in terms of being reliable and efficient. I don't suggest CX series for high end pcs.
ok sweet cheers i wasn't aware of that
they're reliable and very silent. i can't really talk shit about other PSU brands because i've only ever used EVGA.
