I am moving to the UK from the states soon and I was curious if I could just buy a wall plug for my Corsair PSU to fit the UK sockets?
Yes it should work no problem since the current lineup of PSU are auto switching and can handle 110-240V.
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5543619
Yes, the power supply will automatically switch to the new voltage.
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5543621
Great yeah I just bought my PSU last week it is the RM 1000 I just wanted to check before frying my computer
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5543630
Wow, technology. :o
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5543646
You want one of these cables for UK.
http://www.amazon.co.uk/World-Mains-Kettle-socket-Connector/dp/B0011YI5II/ref=sr_1_1?&ie=UTF8&qid=1437483556&sr=8-1&keywords=power+supply+cable
You can also buy them from high street stores such as RS Components, PC World and Maplin but you will probably pay more there.
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5546312
Nice thank you
https://linustechtips.com/topic/411885-i-need-a-cable/#findComment-5555803
