I have watched Linus build many computers and now that I have the money I want to build an All-Or-Nothing PC. The thing that confuses me is the compatibility between components. So far I have
Processor: (i7-5960X)x2 $1000ea
Motherbord: Z10PE-D8 WS $565
SSD: (Samsung 850pro 1tb)x2 $500ea
Hard Drive: Seagate 6 TB Enterprise Capacity HDD SATA 6Gb/s 128MB Cache 3.5-Inch Internal Bare Drive (ST6000NM024) $350
Sound Card: ASUS Xonar Phoebus ROG Gaming Soundcard Set Sound Cards $320
Graphics Card: (AMD Sapphire Radeon R9 295X2)x4 $1800ea (2 in crossfire and the others for other screens, triple screens
Case: Cosmos II
Help finding 512gb 8DIMM DDR4 2133mhz Ram
Tell me if I am missing thing, lack compatibility or recommend something. I am looking to game but work as a 3D animator. My budget is unlimited as i will save what ever is necessary.
Thanks
https://linustechtips.com/topic/411192-first-custom-build/
Get a CPU Cooler so you can overclock
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535187
Case: Cosmos II
Thanks
Okay first of all, you don't need 2 I7 5960x CPUs, one will be fine.
Second, you can't run 4x 295x2 GPUs, the 295x2 is a dual GPU card. and you can only run 4 GPUs in one system.
5820k and two 980 Ti would be fine for you.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535195
Good luck mounting the rads for those 295's, either get a custom loop or go for 6 titanx's or something (3 on each cpu)
you can run 4 because its dual cpu...
They want a stupidly overkill pc let them.
Gaming PC: CPU: i7 4770k@4.2GHz w/ CM Nepton 140xl, GPU: Gigabyte 1070 @2050, RAM: ADATA XPG V1 16GB@2133MHz, Mobo: MSI Z97 Gaming 7, Case: Corsair NZXT S340.
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535203
Reading all of this again, I think it's spam. And being the fact that this account has one post..
I'm going to agree, still a fun brain exercise though. :P
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535219
unless your throwing 4 videos to render at the PC at once you dont need TWO 5960x's only a 5820k... or a 5930k, Pick your poison, a 980Ti and a SINGLE 5930k will be fine it should look something like this ; it would be more suitable for everything in general, judging what people have said, probably right. I'm doing this for the hell of it, No one would even think of putting 2 5960x's on one board.
the idea is Ludicrous. I also didn't sake prices into consideration b/c I knew that it would be well over 5000 judging by 2 5960x's and 2 R9 2 whatevers
Oh if that wasn't enough just throw another 980Ti in there if you feel like waiting more money
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor  ($499.99 @ Micro Center)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($139.99 @ Newegg)
Motherboard: Asus RAMPAGE V EXTREME/U3 EATX LGA2011-3 Motherboard  ($521.98 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($177.89 @ OutletPC)
Video Card: Asus GeForce GTX 980 Ti 6GB Video Card  ($659.99 @ Amazon)
Case: Corsair 750D ATX Full Tower Case  ($119.99 @ Micro Center)
Optical Drive: Lite-On iHAS224-06 DVD/CD Writer  ($169.99 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)  ($149.95 @ B&H)
Sound Card: Creative Labs ZXR 24-bit 192 KHz Sound Card  ($199.99 @ Amazon)
Total: $4171.41
Generated by PCPartPicker 2015-07-19 22:44 EDT-0400
Edit
I will also slap you if you say this is to play minecraft at max settings.
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535251
Total: $4171.41
Edit
I like this build but this posts point is for something stupidly overkill I make animations for frinds and family as well as work and my current pc which can run far cry 3 at 87 fps can still takes an hour to render my half hour animations and i usually render multiple at once. I have had this pc for a while and have upgraded it a few times but maybe the problem is not the hardware.
Also before you judge i used a pregenerated build and just did what the tutorial said.
Edited by Captain Ninja Kid
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535285
I only play MC with my younger sister when she is visiting... She doesn't know the difference beetween the NES and SNES.
Thank god and if your 100% serious about this, you'd want a Xeon E5, do a little Overclocking on the CPU to get it up to gaming standards, its still beyond overkill for all of this... I dont even know what Linus himself would say. I left out a sound card because they are really not necessary unless your into audio creation. To get the best gaming proformance your going to want to overclock the CPU, not the best idea for a Xeon because they're Xeons. But it should get the job done with a turbo frequency of 3.5GHz, not ever game will utilize all 10 core b/c they didn't intend games to be played on a Xeon, it will work, yes, just not as well as an i7
Motherboard: Asus X99-E WS SSI CEB LGA2011-3 Motherboard  ($476.02 @ Mwave)
Storage: Samsung 850 Pro Series 1TB 2.5" Solid State Drive  ($486.97 @ NCIX US)
Video Card: EVGA GeForce GTX Titan X 12GB HYBRID Video Card  ($1036.47 @ Amazon)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer  ($52.98 @ OutletPC)
Total: $7374.38
Generated by PCPartPicker 2015-07-19 23:03 EDT-0400
https://linustechtips.com/topic/411192-first-custom-build/#findComment-5535358
