More Led Help Needed
Solved by W-L,
HI Guys My names Ethan and I have more questions on leds
ok so I found some leds that are surprisingly really good (5050's rgb)
Problem THE ADHESIVE
the Adhesive Is SOOOOOOO Bad Its so bad I dont even think it knows what to stick to (hellan kellar of adhesive)
so should i use Sticky tac or tape or what ?
Just replace the double side tape with something like this it's super sticky, that or place it on a rigid backing with magnets or a really good magnetic strips:
http://www.homedepot.com/p/3M-Scotch-1-in-x-1-66-yds-Outdoor-Mounting-Tape-411-DC/100575385
