So I have a 500GB Samsung SATA hard drive and about 15 minutes ago, Windows started to lock up. It locked up so much that I had to use the reset button to restart but all I get is a black screen. However, I left it and now it's showing the pink background of the grub bootloader. The HDD light is solid and it's making a clicking noise. Now what!
https://linustechtips.com/topic/411031-hard-drive-struggles/
buy a new hard drive...
https://linustechtips.com/topic/411031-hard-drive-struggles/#findComment-5533297
Seeing as you have grub loaded, try go into the linux distro you have installed and check the smart status. might just be a borked windows install, in which case a good old offline disk check + a /fixboot /fixmbr should do a trick.
But year, clicking hdd means it is dead/dieing get the new drive and then attempt to save your information
https://linustechtips.com/topic/411031-hard-drive-struggles/#findComment-5534470
It managed only to show the background. Nothing else.
https://linustechtips.com/topic/411031-hard-drive-struggles/#findComment-5534524
Hi there.
Basically a clicking noise is not a good sign. Still you can run a chkdsk test on the drive and see what the results will be. Just make sure you to make a backup of your most important data a priori.
If you're using Windows you can run a chkdsk /r on the drive with CMD to see what the results will be. Click on Start, type CMD, press enter, and in the black windows that will appear type chkdsk [write the letter of the drive:] /r.
In case the results show there's something wrong, look for a replacement drive.
Hope this helps and let us know how it went. :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/411031-hard-drive-struggles/#findComment-5537313
