I am looking to a Surface pro but it is a bit pricy and I was wondering if there are any other good options. ps I plan to do lite gaming.
What kind of gaming? What games? What is your budget? Do you need 8.1 Pro? Will a Surface 3 cut it for you?
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533059
What is the point of the surface pro? Are you looking for a tablet or something like an ultrabook (ultra light compact notebook). Is the point battery life or did you want something with more oomph performance wise.
Details are important.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533062
I own the Surface Pro 2. I have to say, you can game on it. Is it the best gaming device? No. You will have issues with storage, USB port space, heat. I purchase the Pro 2 because I always use a tablet before bed, and wanted something I could use as a laptop plus in bed for watching YT videos or whatever else. I would NOT purchase this if you just plan to use it as a laptop.
blackshades on
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533075
If hes going to be doing gaming the Atom will not cut it. He should be looking for a pro model with full windows 8 none of that RT crap. If you get one with an i5 3rd or 4th gem light gaming will be possible maybe(?). There could be heating and throttling issues.
Consume The Darkness
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533165
A surface 3 has full Windows 8.1 Core and can run Win32 applications. And gaming performance will be limited by the GPU. That is why I asked what kind of gaming.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533272
Well I kinda want the tablet pc style computer.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533332
yeah I want it to use as a tablet and a laptop.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533335
like hearthstone,civ,and maybe some minecraft, To be honest I don't know the advintages of 8.1 pro and that is why I am asking.
Do the words Active Directory, Hyper-V, VHD booting or BitLocker mean anything to you? Then you don't need Windows 8.1 Pro. Full list of added features can be found at https://en.wikipedia.org/wiki/Windows_8_editions
For these games, I honestly don't know how much CPU they need. Hearthstone can run on iPhones, so that will probably run fine on Surface 3's CPU. Not sure about others though.
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533359
Yah but no matter how you look at it the Atom that powers the non pro surface 3's isnt going tp cut it
https://linustechtips.com/topic/411007-surface-pro-or-no/#findComment-5533453
