Ok so ive been running with intigrated graphics for awile on the assumption that my GPU was dead. However when i plugged it in today the lights and fans on the GPU turned on, but when i have the GPU plugged into the PSU via the PCI-E 8 pins and the PCI-E slot on the motherboard the system refuses to boot. All the fans are running but i am not getting a bios or windows startup. Any suggestions?
https://linustechtips.com/topic/410952-system-refuses-to-boot-when-gpu-in-installed/
Specs
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
The GPU is failing to post? Hmm, try taking out your cmos battery for like 30 seconds and reinstall it. Sometimes that helps stuff like this. :P
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
Specs
CPU                            I7-4790K
GPU                           GTX 980 TI (G1 GAMING)
RAM                           16GB GSKILL 1600mhz
MOTHERBOARD        MSI X POWER AC
STORAGE                   SAMSUNG 850 EVO SSD (500gb)
Also i should mention that the usb ports do not light up or turn on my keyboard/ mouse. though they seems to be able to charge my phone.
CPU                            I7-4790K
Power supply make and model?
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
I took the CMOS batterey out then put it back in. Nothing.
If you can try the card in another system do it, and if it does not start up there either, the card is dead. Send it in for RMA
try the card in another system, if it still doesn't work, then it's dead
CPU- i7 5960x MOTHERBOARD- Asus Rampage V extreme RAM- 32gb Corsair Dominator Platinum ddr4 2800mhz GPU-  2X EVGA GTX 980 SC in SLI PSU- Corsair ax860 CASE- Corsair Obsidian 750d COOLING- EK cpu+dual gpu custom loop (ek supremacy evo, dual gtx 980 copper/acetal waterblocks) MOUSE- Logitech g502 proteus core KEYBOARD- Ducky shine 3 cherry mx blue switches and blue LED MONITOR- Samsung u28d590d UHD  STORAGE -  120 gb samsung 850 evo ssd, 960 gb ocz trion ssd OS- Windows 10 pro http://pcpartpicker.com/p/jtP8GX
I really don't have another system to test it in. When i asked the people in best buy about it they put another card in my system and that seemed to work. Iv'e already requested an RMA.
