I just received my new headset, bought it off Amazon. I have the Sades SA-808 Gaming Headset. I am having difficulty on picking up the mic and wondering if I connected it correctly. The headset has A USB port for lighting, a headphone and microphone jack. One color is green and one color is red.
I usually use an HDMI cable from my PC to my TV. I tried connecting my headset to the audio jacks on the front of my PC (audio and microphone) however I heard nothing. I then tried to connect my headset to my TV, it contains a USB port, and (I believe) 2 jacks, however they are far from each other and the leads are too short, so I wasn't able to connect them on the TV.
Troubleshooting, I decided to use a DVI/VGA cable and connected it to my TV. I'm currently trying to hook up my headset and so far I was able to get sound. I am using the rear I/O and cannot seem to pick up a microphone.
Does anyone know how to fix this?
https://linustechtips.com/topic/410507-gaming-headset-help-connectivity-issues/
^ and make sure you set the headset as your default device instead of what most likely your is set as your TV
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
