Help me build a power pc
i have just over 2,700$ ish to spend on a powerful pc that will be doing allot of video editing and rendering. it might not ever be played on for games. Also the computer will have other programs that need allot of computer power. It might use unreal engine 4 stuff like that. if you need any more info let me know
I made this list assuming you don't need any peripherals such as mouse/keyboard/monitor if so I'll add those later
Intel Core i7-5930K Intel Core i7-5930K 3.5GHz 6-Core Processor
I use this cooler and it's pretty alright - Cooler Master Nepton 240M Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler
I prefer MSI for mobos - MSI X99S SLI Plus MSI X99S SLI Plus ATX LGA2011-3 Motherboard
It will help with your work some, and since gaming isn't a priority i doubt you'd need a 980 ti, although you could switch out with that if really needed.
I only chose a wi-fi adapter if you don't have access to a wired connection.
