Hi everyone, I was hoping someone could help me with AMD driver update.
The catalyst 15.7 driver found here: http://support.amd.com/en-us/download/desktop?os=Windows+8.1+-+64
Says it support my graphics card (7870).
The problem is that whenever I install it and check the catalyst software, it says version 14.4.
How do I update to 15.7?
Note: I'm running Windows 8, not 8.1 (is there an issue with that?)
Thanks for the help.
https://linustechtips.com/topic/410401-amd-driver-help/
are you using the auto detect thing ? if it is download it manually
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5526026
I was afraid that was the issue. Do you think the windows 7 drivers might work?
but you can upgrade for free to 8.1 right?
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5526098
I have an oem product key so when I use the windows installer tool it says I cannot update.
Just update it through window update? Or download the ISO and do a clean install.
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5526701
Just go to windows store and the update should be ready to download (maybe windows update can too, not sure). Also understand you need 8.1 to update to Windows 10.
Watching Intel have competition is like watching a headless chicken trying to get out of a mine field
CPU: Intel I7 4790K@4.6 with NZXT X31 AIO; MOTHERBOARD: ASUS Z97 Maximus VII Ranger; RAM: 8 GB Kingston HyperX 1600 DDR3; GFX: ASUS R9 290 4GB; CASE: Lian Li v700wx; STORAGE: Corsair Force 3 120GB SSD; Samsung 850 500GB SSD; Various old Seagates; PSU: Corsair RM650; MONITOR: 2x 20" Dell IPS; KEYBOARD/MOUSE: Logitech K810/ MX Master; OS: Windows 10 Pro
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5528261
Im doing a clean install right now but for some reason my ssd won't install. Says install files missing. So I installed it to a hard drive and I'm cloning it to the ssd right now. It's taking a very long time.
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5534476
can't find it in the store.
Apparently that is not unknown. Try this link: http://windows.microsoft.com/en-us/windows-8/update-from-windows-8-tutorial to see how to normally install the update. If that does not work, try the troubleshooter: http://windows.microsoft.com/en-us/windows-8/why-can-t-find-update-store
https://linustechtips.com/topic/410401-amd-driver-help/#findComment-5534787
