PWM pump
Go to solution Solved by Chiobe,
Jump to 7:56
I have the 270 PWM D5 pump/res combo. I kinda have a weird loop that the pump isn't strong enough for at its setting when the computer starts.
I have to go into MSI command center to turn the pump up before my cpu over heats..
Its at like 15% at boot.
How do i make it stay at 50% all the time through the mobo header?
Is the setting in the BIOS?
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
https://linustechtips.com/topic/409768-pwm-pump/
Should have bought Ek 4.0 Pumps and EK RES.
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
https://linustechtips.com/topic/409768-pwm-pump/#findComment-5518933
saying "should of bought this" doesn't help my actual problem..
https://linustechtips.com/topic/409768-pwm-pump/#findComment-5518985
EK is disgusting, D5 is the best.
I hope your trolling.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/409768-pwm-pump/#findComment-5525268
