So today my used dell power edge 1950 that I bought arrived at my house! Upon further inspection I found out that in there was NO POWER CABLE!!!! So the first thing I did was to pull out both power supplies and look at what voltage they took and they take 100-120 volts but I went to dell's website and they have a replacement power cable that used 125 volts!!! So do I buy it and use dell's replacement power cable or do I get an off brand power cable that uses 120 volts? Plz help me ASAP! I want to get this server running ASAP!
https://linustechtips.com/topic/409605-server-power-cable/
We have two of them at work and we use just standard kettle plugs.
https://linustechtips.com/topic/409605-server-power-cable/#findComment-5516765
Just make sure the cable is a standard plug that works and of sufficient gauge to handle to load. Most power cables theses days are either 18AWG or 16AWG.
https://linustechtips.com/topic/409605-server-power-cable/#findComment-5516784
But will that hurt the server if I use something more than 120v?
It should be fine. The PSU itself will determine how much draw is coming through the cable. The cable is just "rated" to a voltage of 125V, but could run at any voltage lower then that.
All it means is that the cable has wires that are a specific wire gauge that can handle 125V of power.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/409605-server-power-cable/#findComment-5516788
A standard ATX a power cable is the same as ANY OTHER ATX power cable.
The exception is if it uses a C-19 plug instead of the normal one that 99.99999% of computers/monitors have used since computers existed.
C-19 are used in SOME server applications and I have seen a couple old Dell XPS systems with them.
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=AP9877
When in doubt, re-format.
https://linustechtips.com/topic/409605-server-power-cable/#findComment-5516835
