modding AIO cooler?
Go to solution Solved by Godlygamer23,
AIO coolers aren't really designed to have the tubing taken off.
https://linustechtips.com/topic/409153-modding-aio-cooler/#findComment-5511173
is it possible to change those black tubing on a Deepcool Captain and a Corsair H100i gtx?
No it's non serviceable so nothing can really be done about it unless you want to wrap it in some tubing to change the color or look of it.
https://linustechtips.com/topic/409153-modding-aio-cooler/#findComment-5511178
