I installed an new MOBO (gigabyte GA-78LMT-USB3) and my CPU fan is always on max.
o thought it was just a new startup thing but guess not. Please help its so annoying.
See if there is a smart fan mode in your motherboard's BIOS
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/409141-cpu-fan-always-on-max/#findComment-5511080
If your BIOS isn't very helpful, you could download a 3rd party application to control your fan
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/409141-cpu-fan-always-on-max/#findComment-5511591
I have used that MB before and its own fan control does what it is intended for, so double check the settings on the BIOS and if you can update it i recommend you to do it, another think that came to my mind, is check your fan cable is properly pluged on the CPU fan connector on the MB not on the chassis one, this MB has 2 fan connectors on it.
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
https://linustechtips.com/topic/409141-cpu-fan-always-on-max/#findComment-5511965
