is my system bottlenecking?
Go to solution Solved by ,,,,,,,,,,,,,,,,,,,,,,,,,,,
would it work if I replaced this cpu with a AMD athlon x4 860k?
 Nope, you'd have to go intel or 8320.
If so how do I fix it?
I have a Sapphire Radeon R9 270X 2gb
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202050
AMD Athlon X4 760K
Link:http://www.amazon.com/gp/product/B00D7BYMB2?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s01
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-2133C9D-8GXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231689
I have noticed that my graphics card isnt really performing that well even when on medium low settings on games like battlefield 4
Thanks!
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/409124-is-my-system-bottlenecking/
YES, the CPU.
No generally it should not be bottlenecking. The 270x isn't very high end, an Athlon x4 shouldn't bottleneck it most of the time. You can check GPU usage in games with MSI afterburner, if you're lagging but getting less that 90+ GPU usage you have a CPU bottleneck
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
What are some good options for affordable AMD CPU?
8320, 8350 are pretty much the only nearly OKAY cpus AMD have and you won't get a 270X bottlenecked with either of those.
Should just get an i5 4460 with a new mobo if you could, quite a bit more than just replacing a CPU though it would not bottleneck future, better GPUs..
i7 6700K - ASUS Maximus VIII Ranger - Corsair H110i GT CPU Cooler - EVGA GTX 980 Ti ACX2.0+ SC+ - 16GB Corsair Vengeance LPX 3000MHz - Samsung 850 EVO 500GB - AX760i - Corsair 450D - XB270HU G-Sync Monitor
i7 3770K - H110 Corsair CPU Cooler - ASUS P8Z77 V-PRO - GTX 980 Reference - 16GB HyperX Beast 1600MHz - Intel 240GB SSD - HX750i - Corsair 750D - XB270HU G-Sync Monitor
