Hi all,
This is my first post so please be gentle :-) I have been a long time fan of linustechtips and I know you guys are the ones to ask about PC builds. I have a good friend who is looking to do a budget PC build with the most performance she can get and I wanted to see if we could get you guys input.
See specs here https://www.reddit.com/r/buildapc/comments/3dj2l8/first_build_feedback/
https://linustechtips.com/topic/408904-pc-build-help/
The core i7 is pointless in gaming over the i5.
Why not get z97 board.
Get the 980ti from the money you saved from going to the core i5.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/408904-pc-build-help/#findComment-5508070
Watercooling a CPU is stupid unless she plans to overclock, even then it's more cost-effective to put money into the graphics card. The 980 is in a garbage place for price-performance since a 390x will perform the same or better at $200 less. z87 is outdated now. If you want to save $100 get an i5-4690k instead, gaming performance will be EXACTLY THE SAME
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($146.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.95 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($689.97 @ B&H)
Total: $1616.65
Generated by PCPartPicker 2015-07-16 15:56 EDT-0400
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/408904-pc-build-help/#findComment-5508083
Total: $1616.65
At that price, get the R9 295x2.
https://linustechtips.com/topic/408904-pc-build-help/#findComment-5508199
