The Lenovo E440 vs The Asus X455LJ
For reference:
Lenovo E440:
http://shopap.lenovo.com/ph/en/laptops/thinkpad/edge-series/e440/
Asus X455LJ:
https://www.asus.com/ph/Notebooks_Ultrabooks/X455LJ/
For specs just access the link
I appreciate your feedback
Thanks!
https://linustechtips.com/topic/408581-help-choose-between-this-two-laptop/
For reference:
Lenovo E440:
Asus X455LJ:
Thanks!
Spec? They are just say i3/i5/i7 4-16gb ram ect. they are just generic for those series's
Get the ASUS, it seems to be the all round better machine from the specs and pictures.
[ Rig: CPU: 4930K, GPU: EVGA 780TI SC x2, RAM: 32GB Corsair Vengeance 1600MHz, Mobo: ASUS P9 X79 LE, Storage: 120GB Samsung EVO + 2TB Seagate Barracuda, PSU: Corsair RM1000 ]
•If you were I which one will you choose?
•Which is more reliable?
•Better performance?
•Which will last longer?
•Better keyboard and every thing?
Assuming they are the sames specs and price, I would go Asus.
Show us there real specs, not their product pages. Read the spec list in the store itself.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Guys could you give me some reasons why is it Asus
Please use the quote button. Where are you going to buy from?
No only use it when you want to reply to someone's question.
I'm not going to buy in online. I'm will go to there outlets or PC express etc.. To buy it so that I can see the product and check some parts of it
Alright, go to the outlets and tell us when you find something good so we can check it for you. Because the specs of the laptops you showed will vary.
