Help me choose a case
Go to solution Solved by Matom3,
Thanks for your quick response. I will research these options. Thank you for your opinion
Hi
I am doing a custom build and I cant choose a case that looks beast while being able to fit the requirements that I need.
I am looking for a Full tower case with a side panel window, a minimum of 3 external 5.25 inch drive and has a unique design. I will leave a build link bellow Any suggestions would be greatly appreciated about both the case and build.
I have already had a look at two different cases and I couldn't decide between them so I you think one of those would be better choice.
1. Cool Master Storm Trooper Window: http://gaming.coolermaster.com/en/products/cases/trooperwindow/
2. Phantex-Enthoo Luke: http://www.phanteks.com/Enthoo-Luxe.html
Build Link: http://au.pcpartpicker.com/p/zxszLk
https://linustechtips.com/topic/408544-help-me-choose-a-case/
Hi
Sweet build but 1 thing, try to avoid a kingston SSD, go with Crucial or Samsung, this is because Kingston has a high fail rate when it comes to SSD's
PC Part Picker: https://pcpartpicker.com/b/hZCypg  ProcessorIntel Core i7 6700k ; MOBO: Gigabyte GA-Z170MX-Gaming 5RAMCorsair Dominator Platinum 16GB 2400 MHz (spray painted the top part red); GPUGTX 1070 - Gigabyte Variant (Custom painted the Cooler and Fans Red); Case: NZXT S340 (Red); PSUCX 750W  (Bronze 80+); SSD: Crucial 256GB (Boot drive and for applications) and Sandisk 480GB Extreme pro SSD and a Samsung T3 1TB External USB-C SSDHDDWD Blue 1TB, Seagate 3TB (Both Run at 7200RPM); Displays: Asus something (1080p @ 144hz) and LG 27UD68-W 4K 60Hz IPSLaptop: Dell XPS 15 9550 (i7 6700HQ, 16GB RAM, 256 SSD, GTX 960M)
https://linustechtips.com/topic/408544-help-me-choose-a-case/#findComment-5503156
http://uk.pcpartpicker.com/p/VYH6bv
The Pro is just the Luxe with a few less features. The money saved by going with it will allow you to get an R9 290 which is MUCH more powerful than a 960.
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/408544-help-me-choose-a-case/#findComment-5503182
What do you mean by R9 290?
I changed the graphics card to the R9 920 from AMD. It won't be any more expensive than a 960 + Luxe (case) combo and the Pro is just as nice as the luxe. I have one :)
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/408544-help-me-choose-a-case/#findComment-5504202
