So I was wondering if all my parts will fit in the case and where I can buy a similar or cheaper case because I know the shipping will be high if I try to order it online.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (Purchased For $0.00)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: Mushkin Stealth 16GB (2 x 8GB) DDR3-1600 Memory  ($90.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Best Buy)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Enermax OSTROG ATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($73.15 @ Amazon)
Optical Drive: LG GH24NSC0B DVD/CD Writer  ($16.89 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.99 @ NCIX US)
Total: $692.98
Generated by PCPartPicker 2015-07-15 22:57 EDT-0400
https://linustechtips.com/topic/408418-help-with-my-build/
If ur only gaming then grab an i5 4690k then get a 390x or 290x or 980 instead of the 4790k Get the cheapest 1600mhz RAM u can find, voila now u can have a nicer GPU
Get windows on reddit for 10$ and use the remaniing 70$ to get a 120GB SSD
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501667
may I ask how you purchased them for 0.00$?
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501676
I'm going to be gaming and streaming at the same time. Also idk about buying Windows off of Reddit. That's pretty sketchy and I heard that they have keys that will only last for 90 days or something like that.
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501692
Or just pirate windows, thats 100% free
Still get cheaper RAM and get windows another way, then u can get an SSD
If ur steaming keep the i7 and 390
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501706
Max GPU size for that case is 11.26" (286mm) With Drive Cages & 16.26" (413mm) Without Drive Cages while the R9 390 is 10.91" (277mm) in length so the case should be able to fit everything as long as part picker has right specifications.
Alright awesome, thank you.
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501734
I kind of want to get Windows 10 though.
windows 10 is free upgrade from 7 8 or 8.1
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5501808
Do you know where I can buy Windows 8 for a really cheap, legit, and legal price?
Reddit or from newegg. For all i care get windows 7, its free to get windows 10 after anyway and it comes out in 2 weeks.
https://linustechtips.com/topic/408418-help-with-my-build/#findComment-5509462
