My ISP provided me with a cable modem with 2 ethernet ports and this voip adapter ( http://site.tehsino.ro/admin/upload/Datasheet_of_TVP-111x_Series_VoIP_ATA.pdf ). One ethernet port goes into my home router and one goes into this adapter. I was wondering if I could connect the voip adapter to my home router instead of the cable modem. On the bottom of the adapter there is a LAN address (192.168.10.1) and a MAC address. I tried to connect the adapter to my router but it doesn't show up in DHCP Clients list. I tried to reserve it's address (192.168.10.1) but it gave me this error: " The IP address is not in the same subnet with LAN IP address". The DHCP server goes from 192.168.0.100 to 192.168.0.199 .
Is there anything I could do?
https://linustechtips.com/topic/408031-voip-phone-adapter-help/
The VOIP adapter is on a different subnet then your LAN.
VOIP adapter: 192.168.10.x
LAN: 192.168.0.x
Notice how the second last group is different (10 vs 0).
Can you put the adapter on your LAN? Sure, assuming the adapter is capable of changing it's IP Address (Read the manual).
Should you? If you're not a networking expert (or even enthusiast), then no. Why bother? Just use the specific port on the Modem that is designed for it.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/408031-voip-phone-adapter-help/#findComment-5497594
