Hi everyone! So I recently ordered a 7950 from http://www.superbiiz.com/  and it was supposed to come with 4 games. The Never Settle Reloaded bundle and the Level Up bundle. I got my gpu in the mail today and I thought I was supposed to recieve the codes on a piece of paper or something. But there was nothing in the box about the games. Before I ordered the card last week, I called the website and asked if they were still offering the two bundles and they said yes and that they still have codes in stock. So was I supposed to get the codes via email? I checked their website and it told me to go on my account to check the order status where the codes would be listed but there was nothing there. Should I contact them?
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
https://linustechtips.com/topic/40791-never-settle-reloaded-bundle-help/
Some places you have to get the codes from the store you bought the card from, some time you have to registre the card at the manufactures website and others the codes comes with the card. I have found the Never Settle Bundle to be one of the most tedious things I have ever tried to redeem.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
I guess I can try registering the card. It's a sapphire card
Try and check the Sapphire website to see if they are responible for the bundle. But yes registering the card probably won't hurt you, so it is worth a try.
Well it said on Sapphire's website that I am supposed to get the codes from the place I bought it from, so now I have to call the website. And I have to agree that this is so tedious
Heh ok, I called the website and they said that the code will be emailed to me within 24 hours. Damn, that took way too long!
Welcome to the life of a PC builder. I have redeemed 8 Never Settle Bundles in 4 different ways
