Reference 980ti downsides
Go to solution Solved by SeanAngelo,
Need some advice. For some reason where I live, all the aftermarket factory overclocked 980tis carry a $200 premium. Need some opinions about the reference card such as heat and noise. I am looking at an MSI one but does MSI manufacture the card or is it like the Fury X where they just stamp their name on them?
Reference ones are made by Nvidia, they just put the brand name on it...
the downsides however, they typically run hotter which means its louder due to the fan spinning up and trying to cool the card and don't overclock as much as non-reference ones.
https://linustechtips.com/topic/407450-reference-980ti-downsides/
Damnn $200 extra...
What about the Zotac Amp! (Non extreme) that is actually cheaper than most reference 980Ti's in the UK, or on the same price level and it cools well and is really quite.
The reference ones get rather hot, that's the main downside, so you can't overclock them as well because you'll run into thermal throttling.
Noise wise they aren't that bad, although the fans will always be maxed out at load trying to cool it. And at idle they wont have a 0db mode or anything
And yeah the reference designs are all the same, doesn't matter if it's msi or evga or w.e
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
My understanding is it's just their name stamped on the reference ones.  Only time you see a difference is when its got a custom Cooler and/or PCB.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Thanks guys for the helpful advice. Unfortunately even the Zotac AMP! carries a $100 price premium. Might just settle for a reference card then.
Dont do it.
Safe extra Money a buy a custom Card. Trust me on that, you want a custom design.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
