hi guys unfortunately i had a slight accident involving my PC case and im looking for a replacement side panel
the case i have is an NZXT Phantom 410 (its the white and blue edition)
the side panel is the one on the left with the window
does anyone know of anywhere i may be able to find a replacement?
thanks in advance
https://linustechtips.com/topic/407447-case-side-panel/
Have you tried contacting NZXT?
https://linustechtips.com/topic/407447-case-side-panel/#findComment-5490581
https://www.nzxt.com/product/detail/100-phantom-window-panel-case-accessory.html
I think it fits the 410. Could be wrong. Look on eBay as well.
Edit: Also a cool mod is getting a large sheet of plexiglass and making a giant side panel window. Just a thought. ;)
https://linustechtips.com/topic/407447-case-side-panel/#findComment-5490584
The Phantom and Phantom 410 are different sizes and the side panels aren't interchangeable.
https://linustechtips.com/topic/407447-case-side-panel/#findComment-5491002
