Well, after getting along with my wifes mac I have decided to build my first pc to be able to run games higher than the lowest settings.
My budget is somewhere between $1000 to $1200 (not including mouse, monitor, keyboard, etc.)
I'd like to be able to play most 2014 games and earlier at 1080p @ 60fps on high or ultra settings
I put together some parts and was going to see what you guys suggest.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard (I have no idea what I'm looking for in a motherboard)
GPU: MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Case: NZXT Phantom 530 (Red) ATX Full Tower Case
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply
OS: Microsoft Windows 8.1 OEM (64-bit)
So with all of that I'm a couple hundred dollars over budget. If I could get suggestions on what to substitute and if I should try to buy some of these items used that would be great!
ps Case is not TOO big of an issue but I do like the one I listed.
https://linustechtips.com/topic/407286-first-pc-build/
No need for the core i7 and that expensive cooler for gaming, get a hyper 212 cooler and a good core i5. And get a better SSD like the bx100, the V300 is awful.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488276
Change to i5 4690K and spend more on your GPU if u Want....:rolleyes:
Intel i3-4150 3.50Ghz | MSI B85M-G43 | HyperX Fury 8GB 1866Mhz x1 | Intel HD 4400 | WD Caviar Blue 500GB , Samsung 160GB | Odyssey 450W | AOC E950Sw 18.5In | Windows 10 Pro | Zebronics Armour 2
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488310
The I5 4690k is directed more towards just gaming- stick with the I7 if you are going to use it for more heavy CPU work otherwise I would drop down.
I think you might be able to get away with less memory as well 8GB is pretty good if you need to cut costs
[spoiler=Blue^3http://linustechtips.com/main/topic/388528-blue3/ I5 4690k | Asrock Z97 Pro4 mATX | RAM: Corsair Vengeance (2x4GB) Blue Edition and Corsair Vengeance (2x4GB) Black Edition | GPU: XFX DD R9 390x | PSU: Corsair AX760 | SSD: Samsung 840- 120GB | Hard Drives: 2x1TB WD Blue | Watercooling Kit: XSPC Raystorm 240
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488312
No need for i7 just an i5 will do fine
Only need 8GB for gaming
Don't need that much HDD storage and that SSD is awful get a better one like the Samsung evo series or BX100
Don't need that big of case you can get something like the H440 or R5 for cheaper
And with that money saved up you could get a better GPU like the 390/390X, More SSD and better ASUS mobo
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488334
http://pcpartpicker.com/p/ZgZNwP
here is an awesome build for the price
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488533
For gaming, an i5-4690k will be excellent for you. i7's are made more for recording, streaming, etc. But the 4690k is still exceptionally good at recording and streaming.
GPU wise, take some of the money saved by the i5 and get the MSI r9 390. It preforms better than the GTX 970, but does tend to consume a bit more power. Make sure your PSU can handle it. (750w gold should do it no trouble)
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5488974
http://pcpartpicker.com/p/z8CHTW here. The 390 gives more performance and 8gb of Vram. Unless your going to do editing then go i5
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/407286-first-pc-build/#findComment-5489013
