Power supply help
Go to solution Solved by Castdeath97,
EVGA 500B, try to get the 80 plus bronze one.
What would be the best PSU for this build with out spending a ton of money?
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($136.50 @ shopRBC)
Motherboard: Gigabyte GA-H81M-S2H Micro ATX LGA1150 Motherboard ($67.21 @ DirectCanada)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory ($62.99 @ Memory Express)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ DirectCanada)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card ($261.98 @ Newegg Canada)
Case: Cooler Master N200 MicroATX Mid Tower Case ($49.99 @ NCIX)
Case Fan: BitFenix Spectre 43.5 CFM 120mm Fan ($7.92 @ DirectCanada)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor ($166.57 @ DirectCanada)
Keyboard: Logitech K120 Wired Standard Keyboard ($9.99 @ NCIX)
Mouse: Logitech G502 Wired Optical Mouse ($59.98 @ DirectCanada)
Other: Steelseries QCK Gaming Mousepad ($0.00)
Total: $891.03
Generated by PCPartPicker 2015-07-14 10:43 EDT-0400
https://linustechtips.com/topic/407164-power-supply-help/
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/407164-power-supply-help/#findComment-5486727
Try and spend enough money on a PSU.
V650
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/407164-power-supply-help/#findComment-5486751
V650 is very solid, that's why.
650w? Al the calculators I used say 450 so I though 500 2 b safe...
https://linustechtips.com/topic/407164-power-supply-help/#findComment-5486955
Its always good to have some headroom, so your PSU dont run at max. Also since all PSUs get weaker over time (varies with quality), so is it great to not be too close to the limit as that will increase its lifespan.
https://linustechtips.com/topic/407164-power-supply-help/#findComment-5486992
Total: $891.03
Check the PSU whitelist in my sig. Most PSUs mentioned here are not in that list...
The cheapest I would go on a PSU is the Antec BP550. Made by Delta, super solid inside though not many amps on the 12V rail so avoid super hungry GPUs.
https://linustechtips.com/topic/407164-power-supply-help/#findComment-5487345
