Just ordered a new pc and interestingly it worked out to $100 per liter of case displacement before tax. How much can you cram into a case to produce the most currency dense pc. And what is the dollar density of your pc? I wonder what the average result will be?
https://linustechtips.com/topic/40716-100-per-liter/
http://www.scan.co.uk/products/6gb-pny-nvidia-quadro-6000-sdi-i-o-pcie-20-(x16)-384bit-gddr5-bnc-displayport-dl-dvi-i-sdi-stereo-po
I recon one of them, in a gold plated case with a 1600w psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182251
 A 2tb SSd maybe?
LOL i recon you could get it pretty high ;)
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
https://linustechtips.com/topic/40716-100-per-liter/#findComment-527236
I can just take everything out, buy about 650 i7 3970x's and just dump em all into my case or simply fill it with $100 bills
https://linustechtips.com/topic/40716-100-per-liter/#findComment-527518
