Do I need case fans?
Go to solution Solved by lani100,
Cpu has integrated graphics, will upgrade later. What fans would you recommend that are cheap
The case comes with 2 which should be fine.
CDR-King
Baseline is DeepCool XFan...
https://linustechtips.com/topic/407141-do-i-need-case-fans/#findComment-5486429
