Hi guys, after completing my build I spent numerous of hours in the bios and in the car/computer store to check everything out. First I thought it was a problem with my RAM because everytime I set it to XMP profile 1 I would just get crash and never even make it into windows. They told me that it wasn't the ram and that it could be my SSDS but I didn't think that was the case since I had it working on my old build. I have both smasungs 850 in Raid 0 btw. I'm not sure on how they tested but they did it with in a span of 10minutes. They told me I should just bring my entire system in and have it checked out but it will be gone for a week, So I'm trying to get this solved on my own for now. After setting it to 2 I could finally boot up and make it into windows. I then started to game on but then I got a windows BSOD. Thought it was just a one time thing then it happened again today when I left my computer for an hour. Then I started i Virus scan then I got an instant Crash.
I got the code
BCCode 124
bCP1 0000000000000000
Bcp2 fffffa800ff87028
bcp3 00000000BF800000
BCP4 0000000000200401
CAN anybody please please help me, I spent so much money for this sytem(literally) all my paychecks went into this and I can't figure out why this is happening. I am on a x99 platform with a 5820k and 2400mhz Kingston Predator ram, running at 2133 right now...
https://linustechtips.com/topic/406910-please-help/
XMP is considered overclocking so its not officially supported and the imc integrated memory controller is basically a silicon lottery, you are better off wiping your drives, clearing the bios, leaving off xmp and reinstalling windows
I got the code
BCCode 124
https://linustechtips.com/topic/406910-please-help/#findComment-5483541
I have tried putting it on auto, and I would still get the same issue. I have reinstalled windows 7 2 times now. My last resort would be to bring it in but they charge a lot, 75$ per hour to be exact and I can't afford that much if it takes them longer than 2, heck even 1 hour is a lot for me
https://linustechtips.com/topic/406910-please-help/#findComment-5483597
wipe the drives
https://linustechtips.com/topic/406910-please-help/#findComment-5483605
