I have a 2TB Seagate drive that came out of an external solution. It's been running for at least a year, just for storage.
For around a week now, it makes a noise like a vibrating phone (It makes me check my phone all the time) every 30 minutes or so.
Never noticed this sound before. What do you guys think it could be?
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/
Have you made sure that none of the screws that hold it in place have gotten loose?
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/#findComment-526671
Put something soft under it and you will not hear that noise.
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/#findComment-526674
It sounds bad, maybe you can compare the sound with one of these: http://www.datacent.com/hard_drive_sounds.php
Generally speaking when a drive starts making sounds it didn't make before I would no longer trust it.
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/#findComment-526678
It's mounted with the corsair drive cage thingy
I'll check out those sounds.
Looks like I'll have to get a new hard drive
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/#findComment-526696
Yes, that is the safest option, I just don't trust drives when they start making sounds they never made before.
https://linustechtips.com/topic/40673-hdd-making-vibrating-noise/#findComment-526725
