Lg 29um67 freesync problem
Go to solution Solved by PineappleHolidays,
You need display port
yup startech 1.2 display cable
Is it connected properly to the right connector ?
I would try uninstalling and reinstalling drivers.
Hi !
so my new lg 29um67 just came in and everything is fine but i can't enable freesync for some reason.
i use a r9 290 so it isn't the gpu and got the new 15.7 omega driver but there simply isn't a option to enable it sadly since freesync is so new there isn't much information on freesync.
so after a live chat with lg which went totally great ...... (Lg just random stopped the chat )
so the great forum of linus hopefully can help me.
post-194327-0-43298400-1436791277_thumb.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/406361-lg-29um67-freesync-problem/
Hi !
also when launching the freesync demo it says that my display isn't compatible for some reason ?!?!
afaik freesync works with displayport only, you're using displayport right?
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
late to the party
so, i did a quick google, and nothing i can find about the "29um67" mentions freesync, however i get a lot of results about a "29um67-p" freesync monitor.
sorry 29um67-p i bought this one (sorry for dutch website try translating it )
http://www.monitorstore.nl/product/573526/lg-29um67-p.html?_ga=1.11375348.159670426.1430232919
have you contacted coolblue about your problem? i heard their support is pretty amazing, i'm sure they'll help you out.
could try that and yes else my screen won't display anything
not yet since they only sell it i thought that LG is the guys to look for but since they make it but i could try that
GREAT it worked some how reinstalling the drivers worked now there is a option to enable freesync, i guess when i installed the driver a couple days back it din't fully complete?!?
But thats not a problem anymore so Thanks for the help
this is the reason i went nvidia, just dropping that here.
It's because you used to have a non freesync display :P
Happy I could help
So you don't have to reinstall drivers but in exchange pay 150€ more for the module ?
This isn't really a "reason"
i LOVED my HD 5770, but i had stupid driver issues along the way, which in the end killed the fan. (no vsync was one of the more pressing issues)
