PSU fan
Go to solution Solved by Jlryan,
That's good then, it's probably just a bit of grit either on the shaft of the fan hub or on the stator colliding with the magnet. That's all it takes with these things to cause a racket unfortunately.
If PSU fan were to stop, how long would it be before the over temp protection kicks in? 15 mins of stress test enough?
https://linustechtips.com/topic/406328-psu-fan/
If the PSU fan on that Seasonic unit stops it means it isn't under load.
If you are going to stress test it it should just power on again.
Only the X series and above have that feature. This one only goes down in RPM to say 500-600
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475766
Really depends on the conditions... How much load is being pulled, ambient temperature, if the PSU is still enclosed in a case and the case has positive pressure airflow that can force air though the PSU too.
Too many variables. :P
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475775
Asking since for the past 2 weeks it's been making a ticking noise (not hitting anything, I'm sure) and today I tried pressing the center of the fan several times.  Booted up and it's gone. Usually when I went into shutdown/sleep it would spin down along with the fan and spin up when I rebooted. Some days it was more apparent, other days it was quieter. Now it's silent but I also don't really feel any air coming out the back.
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475785
Can never be too sure with a PSU, try looking underneath to see if the fan is spinning at all, if not get on to Seasonic support and tell them what's happening. They should sort you out with an RMA.
That Seasonic unit should have a 5 year warranty on it.
Photography
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475799
The desk kind of doesn't allow for that :/
I think I could feel air getting sucked in through the bottom.
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475810
Ah I see, well in anycase if it is failing, the failsafes should kick in before any damage happens.
Photography
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475822
Failing . . . .yeah. . . . .it's barely 3 weeks old . . . .
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475832
Haha oh wow, maybe just something catching in the fan bearings from the manufacturing process then? :P
I'm sure it'll be fine though.
Photography
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475850
Probably lubricant dried up :/
The PSU itself is working perfectly fine, hell, from what I'm seeing it's better than the one it replaced. The only thing I'm worried about is that noise. Considering the behavious it was the fan and I guess pressing on the middle either made lubricant flow through or somehow broke it completely.
On a more positive note, I tried with a wet hand seeing as that makes skin more sensitive to air movement, I can at least feel air passing now. That's a start I guess.
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475888
Photography
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475915
Well, If it works it works I guess.
https://linustechtips.com/topic/406328-psu-fan/#findComment-5475925
