Hello there! Soon I'm looking to splash £500 on a portable PC that I can take out and about with me when I go to work, family places etc. (This would also act as a server for me and my friends when I'm not out and about with it)
I have two requests:
1) To spend no more than £500, this including an OS (I can get Windows 8.1 From G2A For £25Ish)
2) I would like it to be as quiet as possible and in the Aerocool Dead Silence Gaming Cube case.
Thank you :D
This PC will be used for light gaming and photoshop + after effects editing. Also could you please build it on PCPartPicker.
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/406277-custom-pc-build/
BUMP
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475158
With that budget - what kind of gaming are you considering?
"light gaming" So thinks like Terraria, Trove, CS:GO etc, I think the Superclocked 750ti would serve that well, which is around £130 I believe.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475162
http://uk.pcpartpicker.com/p/2tPpkL
Nothing special (plus first time I've ever used PCPP)
Since there wasn't really any context as to what you wanted to do with the build, I went for a basic office/production with a little gaming in mind kinda theme.
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475166
Do NOT go with this, pathetic value for money, lemme make one quickly.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475177
This is a good build, but I would love to have a GPU in it.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475184
It's an APU :)
Honestly I chose that because £500 is a fairly limiting budget, my process of choosing that hardware was so you can easily upgrade to a mid-range GPU in the not so distant future, but it's a rig to get you started until you reach that point.
Watch this, the APU's are pretty nifty if you know what settings to limit your games to so you don't overwhelm them.
Photography
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475191
It's an APU :)
Yeah I guess it is, I will note it and see if anyone comes up with anything better.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475194
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£141.22 @ More Computers)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  (£69.00 @ Aria PC)
Video Card: EVGA GeForce GTX 750 Ti 2GB FTW ACX Video Card  (£113.89 @ Aria PC)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£36.98 @ Scan.co.uk)
Total: £487.08
Generated by PCPartPicker 2015-07-13 10:10 BST+0100
This is a solid all round build. A 120GB Samsung 850-EVO SSD would make for a nice upgrade as a boot drive. As for silence, with that budget you cannot really be picky. The CPU will be able to handle gaming and Photoshop with no problems. The 750Ti is the best one available. Decent no frills motherboard, and 8GB is enough for RAM, although you might want to go for a single 8GB stick so that you have the option to add another one in the future for a total of 16GB of RAM.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475208
Oops, was too late, edited my last post to include a video. (Forgive me, I've been up for the last 18 hours :P )
Photography
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475209
Total: £487.08
This is a neat build, I've noted this down as well, thank you very much :D
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475218
You're welcome! I have refined it a bit:
Total: £491.85
Generated by PCPartPicker 2015-07-13 10:17 BST+0100
Added a single 8GB stick for £4 less, which gives later upgrade ability, and upgraded the HDD to a Caviar Blue, which is more reliable and slightly faster, while making the overall price of the build rise by £4. Worth it in my opinion. You could shave a couple of pounds by going with a 400-450W PSU, but the 500W allows you to upgrade to a beefier GTX960/970 in the future, while coming with a nice 80+Bronze for a VERY good price. Cable management will be a little bit tricky, as it is not modular, but you pay a lot more for modular PSUs, so, beggars can't be choosers xD.
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475245
Total: £491.85
This is far better than the apu build. It offers better fps in games, both with a stronger cpu, and far better graphics solution.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475277
Did some more digging around, Intel prices were much more reasonable than I thought  :P
Here's a better build, though it is slightly over budget.
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  (£58.76 @ Scan.co.uk)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£38.87 @ CCL Computers)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  (£147.59 @ Aria PC)
Total: £504.16
Generated by PCPartPicker 2015-07-13 10:40 BST+0100
Photography
https://linustechtips.com/topic/406277-custom-pc-build/#findComment-5475313
