Hello guys,
I'm about to build my new pc and I'm really worried about the cpu.
Unfortunately i can't afford i7 4790k so i guess I'm stuck with the i5 4690k.
I read some write about hyper threading. I will use the pc for gaming and some civil engineering programmes.
I know it will not be that good comparing to the i7 4790k.
This makes sleep goes away.
I keep wondering if the i5 4690k will fail me or be that bad..
https://linustechtips.com/topic/405554-help-me-sleep/
Hyperthreading won't be that big of a difference for you so the 4690K will be just fine after you overclock it.
[ Rig: CPU: 4930K, GPU: EVGA 780TI SC x2, RAM: 32GB Corsair Vengeance 1600MHz, Mobo: ASUS P9 X79 LE, Storage: 120GB Samsung EVO + 2TB Seagate Barracuda, PSU: Corsair RM1000 ]
https://linustechtips.com/topic/405554-help-me-sleep/#findComment-5465616
I'm very certain the 4690K will meet your needs.
https://linustechtips.com/topic/405554-help-me-sleep/#findComment-5465617
Fusionblitz is correct, for gaming, you don't need hyperthreading.
Evidence: I have a 6 core AMD cpu, and AMD doesn't have hyperthreading on any of their cpus.
https://linustechtips.com/topic/405554-help-me-sleep/#findComment-5465665
