Hi guys I am having an issue and I don't know how or what to do anymore the computer when it is out of the case it boots and lets me navigate the BIOS no problem but whenever I place it inside the case it doesn't boot up the only difference between being outside and inside is that i just my exacto knife to start it any suggestion will be greatly appreciated
the Specs for the are:
CPU: Intel Celeron G1820
MoBo: AsRock H87WS-DL
RAM: Kingston Technology 4GB 1600MHz PC3-12800 240-Pin Single Rank DIMM Memory for Select Dell Desktops (KTD-XPS730CS/4G)
PSU: Ultra LSP-500
Case: IN WIN PE-Series IW-PE689 Pedestal Server Case
the sooner the best thank you so much in advance
https://linustechtips.com/topic/405294-booting-issue/
Is your front panel stuff plugged in, including your power button?
QUOTE when replying to others / Quality over Quantity in your posts / Avoid ambiguous topic titles
Desktop: "Shockwave" Core i7-5820K / GTX 970 SSC / ASUS X99 Deluxe / 16GB DDR4 / 120GB Samsung 850 EVO / 2TB WD Black Caviar
Laptop:  "Archippos"  Dell XPS 15:  Core i7-7700HQ  /  GTX 1050  /  16GB DDR4  /  512GB NVMe PCI-E SSD
https://linustechtips.com/topic/405294-booting-issue/#findComment-5462452
Have you tried using the knife to boot it up inside the case? Does that work?
Its likely a short, are all your standoffs in the right place?
Main Rig:-
Server:-
https://linustechtips.com/topic/405294-booting-issue/#findComment-5463010
I tried to boot it from inside with the knife already and yes I re did the build and check EVERYTHING twice sir.
I've heard of this issue before but no one was able to find out what happen :(
https://linustechtips.com/topic/405294-booting-issue/#findComment-5463315
