Hello Forum,
I wanted to change the backup location of iTunes since my C: SSD is only 120GB. I also want it to save the downloaded or synced apps and music to my HDD. I tried to change it using this (http://www.howtogeek.com/164275/how-to-change-the-backup-location-of-itunes-or-any-windows-app/) guide but Command Prompt shows me this: https://imgur.com/Py1LMbe
I tried it for the backups, but I'd also like to do this for the Music and Apps.
Thanks! :)
CPU: i5 4690K @ Stock                GPU: Asus GTX 970 STRIX @ Stock      SSD: Samsung 850 EVO 120GB (OS and Drivers)     Headset: Audio-Technica M20X
Case: Corsair Obsidian 250D        RAM: Kingston HyperX 16GB LP             HDD: WD Caviar Black 2TB                                         Mouse: Logitech m185
OS: Windows 8.1 OEM                 PSU: Corsair RM650                                Motherboard: Gigabyte Z97N Mini ITX                         Keyboard: Corsair Gaming K65 RGB
https://linustechtips.com/topic/404997-itunes-backup-location-problem/
mklinink /J "%appdata%\Apple Computer\MobileSync\Backup" "E:\iTunes Backup"
EDIT: you also need to open CMD as administrator.
That's why. I actually am admin. I guess I'll open it as one.
But why J? I saw that but it's C: isn't it?
SNIP
Shoot. I just did this by accident. How to revert it? https://imgur.com/DJMCf7R
/J is the modifier for the command, i'll toss you a better guide to the command:
mklink /modifier link_path file/folder_path
  • /D – creates a soft symbolic link, which is similar to a standard folder or file shortcut in Windows.  This is the default option, and mklink will use it if you do not enter a prefix.
  • /H – creates a hard link to a file
  • /J – creates a hard link to a directory or folder
SNIP
The shortcut folder gives me the message in the image and the iTunes Backup on my HDD is empty. :((
SNIP
What command?
I mean sorry for the constant spoonfed support I require but I'm an MLG Noob.
What command?
this command.
SNIP
But the E:\iTunes Backup folder is empty.
SNIP
I just deleted all the backups and folders.
