My PC keeps artifacting after an hour of use. I have done CPU and GPU stress tests and they work fine and are not overheating. I run two monitors, one is a 24 inch 1920x1200 and 17 inch 1280x1024. The 24 inch is the one showing the problems.
This screen shot shows everything as normal using printscreen.
My PC specs; Processor: Intel i5 2500K @4.6GHz, Graphics card: Sapphire AMD R9 Nano 4GB DD Overclocked @1050MHz Core and 550 MHz Memory. Hard Drives: 500GB Seagate Barracuda 7200 RPM, 2TB Western Digital Green Drive, Motherboard: Asus P8Z77-V , Power Supply: OCZ ZS series 750W 80+ Bronze certified, Case: NZXT S340, Memory: Corsair Vengance series Ram, Dual Channel kit @ 1866 Mhz, 10-11-10-30 Timings, 4x4 GB DIMMs. Cooler: CoolerMaster Seidon 240V
https://linustechtips.com/topic/40494-artifacting-i-need-help/
Here is what i see.
post-31385-0-26266000-1375054378_thumb.j
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524112
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524140
no picture...
I have tried to upload the picture but it wont show
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524151
The GPU is unstable, dial down the mhz.
I dont thinks so, i have done stress tests and only goes to 68 degrees
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524161
post-31385-0-89984900-1375053875_thumb.j
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524178
no picture...
I have uploaded them now.
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524213
That monitor is broken, dude.
Edit: Oh, only after an hour? What the hell, then it probably isn't the monitor...
The monitor does get hot and I had problems with the monitor in the past due to the solder oxidising on the inverter, the other monitor i use works fine with it, i really dont know what it is, does the graphics card not like high resolutions or is it the monitor.
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524440
If it works fine with the other monitor, it is the monitor.
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-524450
After doing some testing i have came to the conclusion that it is the monitor, it has to do with the frequencies fluctuated and not staying at a constant 60Hz, so the inverter has gone again. Sorry for the late update.
https://linustechtips.com/topic/40494-artifacting-i-need-help/#findComment-539714
