Corsair sleeved cables
Go to solution Solved by Hyydrah,
I don't think so, since they sell similar cables specifically for these other PSUs. Even if they do work, you'd still probably be wasting money on cables you couldn't use.
It should be noted that, at least on my AX760, the cables say "760/860 only".
post-15851-0-09686400-1375049728_thumb.j
Cpu:4670k- at stock.... for now Gpu:r9-280x crossfire Cooler:KrakenX40 MB:mpower SP Ram:8gb hyperX beast
https://linustechtips.com/topic/40477-corsair-sleeved-cables/
I might be wrong, but it should do. However you will end up with left over cables. If you have the opportunity buy the corresponding cables to your PSU.
https://linustechtips.com/topic/40477-corsair-sleeved-cables/#findComment-523880
https://linustechtips.com/topic/40477-corsair-sleeved-cables/#findComment-523881
ok thanks :)
https://linustechtips.com/topic/40477-corsair-sleeved-cables/#findComment-523891
On Corsair's site it says that the kit is compatible with 1200/860/760.
http://www.corsair.com/us/power-supply-units/psu-accessories-1/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-red.html
https://linustechtips.com/topic/40477-corsair-sleeved-cables/#findComment-523895
