Hey
I'm looking for a new tower and I'm stuck between the nzxt phantom 630 and the nzxt h440 Razer edition
what should i get and why, im comming from the old phantom
My build are:
Asus Maximus Extreme VI
Intel i7 4770k Watercooled by CoolerMaster eisberg 240L prestige
Gigabyte gtx780 GHZ edition
Corsair Vengance 2x8GB 2400mhz CL11
Corsair cx750m
MB: Asus Maximus VII Formula -- CPU: Intel i7 4770K -- Ram: Corsair Vengance 16GB  -- GPU: Gigabyte GTX780 Ghz -- Case: NZXT H440
PSU: Corsair CX750M --Display: Samsung 23" 1080p LED -- Labtop: Acer Aspire S7
Keybord: Razer Deathstalker -- Mouse: Razer Naga Epic Chorma -- Mousepad: Razer Goliathus XL -- Speaker: Razer Leviathan -- Headset: Razer Tiamat 7.1
https://linustechtips.com/topic/404216-help-need-a-new-tower/
H440 hands down
Why that tower i know it has a cleaner look but the airflox i can get in the 630 is better or?
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5450091
Dont know both cases. I can recommend the 760t. Beautifull and big with 1a airflow. :P
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5450307
I did look at it, but I'd like to hide the front 5.25" bays better if I'm gonna have them at all  :) and im not the biggest fan of the hole side being clear, or the honeycomb fan filter in the front ;) Except for that it is a cool tower  :P
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5450443
Do you still want front bays, I skipped on the H440 and went with the S340 and am a Very VERY happy man with it. And fits a 240rad.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5450456
Only thing i really use in the front bay is my Asus ROG panel, i didn't really look at the s340 i must admit, but i just did again my concern is the airflow even on the h440 i know there is more flow on the top, but doesn't the front kills the fans i dont reallly see where the air is comming from ?
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5450545
No issues with it getting air in, trust me there. I've done a 140 on the top and it clears the air out, I'm still running stock cooler and my idle temps in below 45, gaming it just peaks 50. which on stock cooling I'm super happy with.
Those front ones might look coverd but trust me lots of air. I took it over the H440 due to cost, and size. I don't need a case that big. Hell if my 970 would have fit I would have bought the Air 240
Redstone:
Obsidian:
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5493078
*EDIT*
Looking at all your Razer gear, You HAVE to get the H440 Razer edition. The case is built for you :P:P
Redstone:
Obsidian:
https://linustechtips.com/topic/404216-help-need-a-new-tower/#findComment-5493082
