Hey guys
I have a question about my current keyboard :)
I have the logitech k120 and i play mmo and fps games with it
And i wanted to ask
What is the difference about buying a gaming keyboard with cherry switches
or these keyboard buttons :)
Thanks for reading
Everything Digital
https://linustechtips.com/topic/40414-question-about-cherry-switches/
Cherry switches feel different when you type on them compared to membrane (regular) keyboards.  Most people prefer the feel of Cherry switches, and there are several different types.  You will basically have to go to a store like Fry's or Best Buy or Microcenter if you have one near you and look for some mechanical keyboards to try out, then you will understand the difference.  It is hard to explain with text or pictures.  Look for a store with a Razer Black Widow on display or something, that's usually the one you'll find on store shelves the most.
Most mechanical keyboards are higher build quality as well.
Thanks for the comments
But i have another question :P
Is it hard to push cherry switches
or are they like laptop keyboard buttons:)
they dont need more force in general , the switches are just more precise, Of course it depends what switches you get, but say reds, which are used in most gaming keyboards, dont require much force at all, they just have a linear constant feel when pressing.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
Depends on which switches you use ^^
Blacks -> Hard to push react in a straight line
Reds -> Easy to push react in a straight line
Blues -> Little softer to push than blacks, and have this tactile click about halfway through
Browns -> Little softer to press than blues, same tactile click.
Black / Red / Brown -> Quiet
Blue  -> Very clicky ^^ [<3 them]
oh and there's greens, really hard to press and click, but hard to find ^^
Frost upon these cigarettes.... lipstick on the window pane...
There are many varieties, named by color.  Brown and Red only require very light touch.  Blue, black, and clear take more.  Green takes a lot.
"Hard" as in 60cN for actuation.
Still isn't a lot, but hard compared to red with 45cN.
Not as hard as some of the cherry switches for non keyboard use, or superblacks.
