Simple Question: About DVI Cable
Go to solution Solved by Glenwing,
Yes, that will work. The extra pins are only extra, to support VGA adapters.
The two are compatible. As already stated, the extra pins on a DVI-I connector are for VGA adapters - the extra pins carry analog signals.
